Gorgeous 8 second 4V
bottlefed97
Orlando, FL
Quoted from Need2Speed.com
This is a good recipe for any of you Modular peeps who want to go fast, very fast without spending TOO much.
This car went well into the 8's on the last combo, at 154ish MPH. He just got this build done, and it went 9.2@160 the other day on DR's. He put the slicks on, and should be going mid 8's real soon.
4.6 DOHC - 1998 Cobra
Stock Block, bored .020 over
Diamond Coated Pistons
Modmax Billet I beam rods
Stock Cobra crank
Stock heads, stainless valves, Manley Valve springs
Stock cams
PT88-47 T4 turbo .96
4" Aluminum Downpipe and muffler
Stainless steel turbo headers and crossover all made by owner
Large front mount air/air intercooler.Same side in and out
Ams500 with C02
Stock 05 style maff with Mafia
83lb injectors
Stock intake, ported, shortend runners.
327 gear,Moser 33spline axles spool and c clip elim,girdle,braced and welded tubes
Home made upper and lower rear control arms and anti roll bar
Strange front brakes.Stock rear brakes with cross drilled rotors
Aluma star 2.0 fronts.Weld Weldstar rears Black with Black Chamipon beadlocks
MT 295/55/15 Dr's
TH400 Trans
Alot of stock parts for an 8 second car!
95PGTTech
he's on SVTP
what do you mean, without spending too much?
the guy is an awesome fabricator, and it STILL cost him an arm and a leg to build that track-only car.
bottlefed97
bottlefed97
Orlando, FL
95PGTTech said:
he's on SVTP
I didn't write that, just quoted it from the original thread lol.
thorco3
IN
well, they started out stock, I'm not so sure I would still consider them stock though
but either way, it is an awesome car, very clean
ARdoller
-Never Forget-
worked over or not, im just kinda surprised you can get a 4V anywhere near 8's without at least aftermarket heads and block.
What aftermarket blocks and heads are gonna be better than a Teksid and 4V Modular heads?
Teksid blocks are used in 2000+hp race engines and the 4V heads flow more than enough to make huge power with FI.
Look up John Mihovertz.
95PGTTech
It's a 9.2 car, not an 8 second car. When it runs the number and backs it up, it's an 8 second car. Cut the ricer math.
"John Mihovetz"
On that note, his combination is an extremely modified stock block and head combination, to the point where the cost would be the equivalent of 302 guys using aftermarket blocks and aftermarket heads. Granted, stock 03-04 longblocks can easily make 650whp all day on stock longblocks with twin screws and more with turbochargers. That's still big numbers in my book on stock longblocks, but let's not start this you can make 2000HP on B heads and Teksid blocks statements.
duff daddy
auto_x5.0 said:
OnyxCobra said:
Alexr said:
that thing runs 8's with the stock block, heads, and intake?
i might be using the wrong engine lol
that's what Im starting to think, lol
Although I dont like 4v's I cant say enough about the quality and abuse the block stands up to. As far as B heads they do work well in a forced induction application.
As Bob said, Stock Teksids are awesomely built, modular heads are strong, even though the new TF has come out and is still in the "testing" stage the other castings both 4v and 2v are super strong.
One thing no one seems to notice is the car has BEADLOCKS on DRAG RADIALS!!! thats big time right there. RTCTTFMF!!!!!!!!!!!!!!!!!!
bottlefed97
bottlefed97
Orlando, FL
Not my math, like I said I quoted this whole thing from another website.
"This car went well into the 8's on the last combo, at 154ish MPH"
Obviously it has been 8's, so it is an 8 second car.
