99GreenStang
- Joined
- Jan 18, 2013
- Messages
- 726
- Reaction score
- 14
Okay update I got fuel lines installed finally but I realized that I forgot to put some sealant on the pipe fitting side of the adapter that goes into the fuel pump which also caused a leak but I fixed that the other day had to remove the lines and drain the gas out of the tank into a small gas can and then take the fittings off the fuel pump and I put some of the Permatex with PTFE sealer on the threads and put em' back in and reconnected the lines and NO LEAKS AT ALL NOW! YAY! LOL.
Although I have a couple other issues now. The issues I have to address now is adjusting the choke and my new Optima Red Top battery is DEAD ALREADY! So I don't think my Tuff Stuff One Wire Alternator is charging but I wasn't sure of the wiring when I connected it either because I was using the original alternator before off of the 3.8 V6 and I had the wire I'm using now spliced into some of the original factory alternator wires but I don't think it's correct now on this new Tuff Stuff One Wire Alternator which I wasn't sure if it was right when I installed it too be honest but I'll go to my local Napa here soon and get a new cable made that runs from the terminal labeled "Battery" on my new Tuff Stuff One Wire Alternator and I'll connect it to the positive terminal of my starter solenoid (which the positive battery cable is connected too" which is what the Tuff Stuff One Wire Alternator instructions that I read online say you can do. So that will solve the charging issue and thus the dead battery problem. But I can't address the choke issue until I solve the alternator charging issue. I also need to call Quick Fuel Monday and ask a few questions regarding setting this electric choke.
I'll keep y'all updated!
Thanks for reading,
Cameron
Thanks for reading,
Cameron
