Hair Ripping out pain! PI Intake Help needed!!
Naptown_Stang
Hey guys. for all of you who have done the PI intake swap i have a question. why am i leaking so much coolant?
Is there supposed to be a gasket for the thermostat housing? I sealed it with Silicone but it seems to leak a little still
Secondly, I used new PI intake gaskets which is what i was told to use, i put sealant on the gaskets, torqued the manifold and Im still getting a lot of leakage. Should i go back and re torque the manifold after the gaskets have seen pressure and fluid?
thanks for the help!
pp_puncher
I was in the same boat. Yes there is a t-stat gasket. It is a black rubber ring seal. Also I used the pi gaskets and put rtv around all the ports. I had to remove it twice to get it right.
Naptown_Stang
Naptown_Stang
yes i cut it off. It wasnt the best cut because i just used clippers. I geuss we need to take that. out. PPuncher. you bought brand new gaskets right? what do you think of my theory of the gaskets getting wet and working?
pp_puncher
Nope, they were the gaskets that came in the engine I bought with 80k+ miles. The gaskets are re-useable and I used needle nose pliers to pull off the tabs. Make sure you use some good permatex rtv, i used copper. Also make sure you lay the manifold down perfectly, and allow the rtv to cure. (24 hrs)
Naptown_Stang
Naptown_Stang
oh, we didnt let it cure, crap. We used silicone from permatex. will it still cure if we ran it and it leaked and let it sit overnight?
Lee12609
The permatex beds to cure for a few hours before seeing water, after being torque, then you can add water but I wouldn't let it run with the cap on (building pressure) for atleast 12 hours.
JDwhite98gt
best bet is to redo it at night and let it sit in the garage, dont drive it untill the next day.
joekd
Ct
I know others here will argue this is the wrong way but I did mine the 1st time with PI gaskets, had a defective manifold which cracked but also had coolant leaks with the PI's (yes, I did RTV everything perfectly and proper set time)
When I redid everything I used non-pi gaskets and not a single problem
Naptown_Stang
Naptown_Stang
oh. looks like i gotta take it apart one more time. thanks for the help guys ill let you know how it goes.
I used PI gaskets and just 2 small spots of rtv. I then let it sit for the weekend before filling it up and running it, never had a leak issue but I had the luxury of not needing my car so time was not an issue.
1Sic98gt
I never used rtv on my gaskets when i did my swap. I ran it within hours of putting the intake on. Never has leaked. I guess i got lucky.
Lee12609
arent you FULL PI SWAP though??
this is only needed when putting a PI intake on NPI heads.
