hating my car more and more
Gregor185
New Tripoli, PA
well guys ive had my car back for a couple months now from getting my pi heads put on and it still ticks...ive replaced lash adjusters and rockers and checked everything out and i still cant figure it out. sounds like an exhaust tick but i cant find any leaks. i dont know what else to do?? im getting so frustrated i wanna get rid of it and i cant say i wanna do that since i just spent 1500 on my seats getting redone. help me out guys please!!!!!!!!!!!
Willis_98GT
DFW Texas
You gotta give us more on here so we can help.. a 4.6 motor will still run with all kinds of noises..
how are your chain guides and tensioners?
it could be bottom end.. bearing of some sort
have you had it up on a lift and ran the car standing underneath?
Make a video and lets go from there.
Gregor185
Gregor185
New Tripoli, PA
ive run it on a lift and it sounds like its coming from the heads. it has only been since the heads were done. and it sounds like its coming from the back 2 cylinders on the drivers side head....
PI96GT
also if its on the drivers side head make sure you're egr is tight, mine had a problem like that
Gregor185
Gregor185
New Tripoli, PA
good point ill try that tomorrow. the car runs great and thats why i have a problem thinking its something internal
GrnGt
If it was your chain tensioners it would be making a loud clanking noise
Gregor185
Gregor185
New Tripoli, PA
well guys i took the car up to a local mustang shop and they think the noise is coming from either the valve guides or there was too much machined off the valves. so they said they wanna pull the heads but i dont have the money for that crap so its gonna have to wait till next year to get fixed! :-(
Ninety8stang
Duh405
Since you said that the tick arose once you put the heads on kind of makes me think you could have a bent valve. I ended up bending the #1 intake valve with the cams im running and had a constant good tick but never had any performance problems. Could be something else to look into when you get it apart. Hope you get it tuned in and figured out.
duff daddy
*e hug* I almost called you to see what was up ith thecar. you may have tweked a valve a hair BUT if it is and the car runs good just run it man it wont urt
nyuk98gt
Gregor185:
If a valve is bent, a compression test ought to show a problem. At least it is inexpensive to do and will give you peace of mind if the compression holds nicely.
HTH,
Chris
96GTPlanB
