Head ???
rz5.0
rz5.0
Great state of TEXAS
18mm bolt holding the accessory bracket right under the ps pump
Enviado usando mi SHP-L710 usando TapaTalk
rz5.0
rz5.0
Add a lower head bolt to that. . Bout to burn this thing down...
g36 monkey
Orlando, Fl
Man that's crazy, I've never had trouble with bolts breaking :( Closest thing is the studs in the water jacket on the timing chain cover.
rz5.0
rz5.0
Rounded the heads off.. Going to get a bolt extractor tomorrow.. it's my fault. . Tried to remove the one by the ps pump with the pulley on. Put the socket at an angle. . Same with the head bolt.. the brake booster put my ratchet at an angle. . Need to get a short extension. .
rz5.0
rz5.0
Finally got it. Took twice as long as it should have. . Dropping heads of at the machine shop in the morning
g36 monkey
Orlando, Fl
Congrats! Hopefully no snags on the reinstall. If you wanna spend a few extra nickels, its worth getting the intakes checked for warpage at the machine shop as well
rz5.0
rz5.0
Man I left the intakes fully assembled. Fuel rails inj harness imrc tb egr all still on them. . At this point I'm just ready to get it back together. I'm already over budget.
g36 monkey
Orlando, Fl
I know what you mean. I was just thinking while you were in there. I know my lower intake is warped because I have a solid vac leak between the two, but am letting it ride for now.
Like I said before, just follow the torque sequences. Though, you are probably pretty well versed in the art of TTY bolts
rz5.0
rz5.0
Never liked using tty bolts. . This will be only the second time ill use them. .
rz5.0
rz5.0
Quick question. . You block the front water passages with the head gasket right?
g36 monkey
Orlando, Fl
This is how it looked for me
senior001
