Header install when heads are off.
98 StormTrooper
Southeast Missouri
I understand that you have to pull off the k member when installing headers. My question is, I'm doing a PI swap so I'm going to have the heads off and the stock manifolds off. Is it possible to install headers then without pulling the k member or can you still not get to the bolts? And is there a difference in the easy of install between long tubes and shorties?
g36 monkey
Orlando, Fl
Are you asking if you can slide the heads into place with the headers installed on them??
If you managed to do that, I would consider you a God among men.
Now, you would probably be able to do that if you unbolted the mounts and raised the motor, but I get that you do not want to do that.
Most people argue shorties are easier to install, but both are an enormous pain and long tubes net you more up top.
Staff member
Lawrenceburg Kentucky
Easier while heads are off? Yes!
Like g36 monkey stated its still a pain, but with the heads out of the way, slipping them in will be easier. Next mount the heads and then bolt the headers to the heads.
Most headers require removing the steering shaft. Do all that while the heads are off. If your starter has any age to it, now be a good time to replace new.
Staff member
Neverenuff, I stole your pic! Perfect example as why headers are a pain and why steering shaft needs to be removed.
Neverenuff took advice from an absolute genius that swapping the steering shaft for this really nice aftermarket one allows more room, ease of install and direct steering responce at the wheel.
JeremyAlan
SN95 Supporting Member
Suffolk, England
I had to install this steering shaft. The LTs kept melting the plastic insert on the factory shaft giving me 10 degrees or so of steering wheel play. It was dicey.
Only downside to the solid shaft is that it transmits way more vibration into the cabin.
DKblue98GT
I don't notice any more vibration but the way the car steers is way better than with the stock shaft.
