heater blower motor don't work
393stroker
My junk 96 gt is pissing me off. The heater blower motor now broke. If its a fuse, where is it and what fuse, if its a vacuum, where is it or what could it be. This car is nothing but trouble. I need to get it fixed real soon, got 2 kids and its cold here.
seriously anytime you suspect a fuse, just go to the box and start in one corner and work your way across until either every fuse is checked or you find a bad one. Takes less then 2 mins and its funny to look up what the bad fuse was listed with to find out it had nothing to do with the blower.
393stroker
Could it be the fuse or what? I'm thinking a fuse, but don't see any bad ones under hood. Maybe a bad one under dash. I just want it fixed
framda
Naples, Fl.
Start with the fuses. Electricity flows like water, it ALWAYS takes the path of least resistance and and always looks for ground (water flows downhill). Think of the switches as valves. You just need to find where it stops flowing. Start at the beginning with a testlight or voltmeter and follow it until you dont have it antmore, bingo there is your problem. Good luck!
