SN95.oh
- Joined
- Jul 13, 2021
- Messages
- 73
- Reaction score
- 19
If your voltage gauge pegs at 18, I assure you the alternator itself is probably fine. The regulator does what it's name is... it regulates the current from the alternator to the car. At idle, there will often be less output, say 12-13 volts. At 1500-3000 RPM, the alternator will usually put out its most power (both amps and volts). So if you check your battery at idle and see 12.5-13v, reach over and ramp the RPM up a little and the voltage should climb closer to 14.5 volts. If you're running the engine at 3,000 RPM and you're not getting at least 13v, then either the alternator or regulator are on the way out.
I'm still learning my way with my Mustang... but I recall older Fords having an external regulator.
The venting on the battery is bad news. If it blew "water" out of the battery, it would be a good idea to pull the battery and clean out the battery box area with baking soda and water. If you have an unsealed battery, do not get any baking soda mix into the battery. The baking soda will neutralize the acid. Left alone, that acid will damage any paint it runs/stands on. Will eventually lead to bad rust issues. Also, I would not drive the car until you get a new voltage regulator on it. Overcharging like it was CAN (not an absollute) cause the battery to explode. Most of the time, it just boils over and ruins the battery, though.... Also produces hydrogen gas.
can i drive it the 2 miles or less to the shop very slowly
