yea unfortunately that was the only way I found that you can have your cake and eat it too with the stance question...
Yeah, I'd like to do the setup you have.yea unfortunately that was the only way I found that you can have your cake and eat it too with the stance question...
Which LCA do you have?I've got the j-shaped/adjustable LCAs also and it works well. Don't forget the cheapest option -cutting coils. Espeicially since you're just adjusting the rear it'd work very well and you probably wouldn't even notice any difference.
for a little $$ you could have someone extend the shock mounting tabs on the rearend. That's the main issue I've found in going low out back -hard to find shocks where you are still in the sweetspot.
In the front I went with drop spindles so my geometry and shock lengths were all still stock, but my CofG was better.
Just for reference, I've got 1in spacers on the front, and 1.5in on the rear and I'm not dead yet. I'd like to buy some quality non ebay ones like I have now, but again I'm not dead yet and I put more stress on them then they'd ever see on the road so you should be fine with them. Just get hubcentric ones if you do.
J&M like these ones?
http://www.americanmuscle.com/jm-jacker-lca-7998-race.html
So these adjustable control arms would come at a "stock height" Then I can simply just lower it and raise it as needed?
Sounds like a sweet deal to me.
335s on 10s? I heard 305 nittos were basically the max on 10s.
Sweet! Well if you guys use the! I'm sure Ill be plenty safe running a good quality ones.H&R Hubcentric Spacers are what I run as well. no problems here and we run way stickier tires than any street tire.
Thanks! I'll check out the pictures!If you look at the customer pic in that link, that was submitted by me after I put them on my car. The only difference in the race ones are the solid spherical bushing on the axle side. They worked great for me. I used them to raise my car to get more tire clearance. I have unknown eibachs in the rear, and even with the fenders rolled, I was rubbing with 275/60/R15. An old school method I seen used by a local shop here to roll fenders is to use a baseball bat and have some friends sit in the trunk.
I think the adjustable LCA is the option I want to go with.
No black Friday deals for my LCA.
well AM has $20 off anything over I think $150. So I could get them for $250.
The MM ones are a little too much than I'm wanting to spend.
Plus free shipping doesn't apply to me... Still get raped at the border.
J&m isn't cheaping out... I simply won't be pushing the limits that I'll need MM ones.meh, my belief is do it right the first time or don't do it at all. if you can't afford to buy the MM arms yet then wait until you can IMO. Not like your car is going to explode from being a little higher in the rear.
