Help with hermonic balancer!
johns94gt
Roanoke, Virginia, United States
Hey everyone ive been dealing with a very bad vibration for the last couple of weeks. I started breaking it down to only 3 things, motor mounts, hermonic blancer and flywheel coming untorqued. Well last weekend i replaced the motor mounts and it only stopped the vibration when sitting at idle. So im gonna replace the hermonic balancer next as i can see the rubber seal pushed out from behind the balancer. And if that doesnt stop it then i guess ill be ripping out the trans again and retorque the flywheel. My question is there anythng i need to know to make the job easier on replacing the hermonic balancer? I have a 1994 mustang gt. Any help would be greatly appreciated john
framda
Naples, Fl.
Don't wait too long or you risk the chance of internal damage. Break the crank bolt loose before you take off the belt (kind of like breaking your lugnuts loose before you raise the car) When you get the harmonic balancer off change your front crank seal. Don't hammer your new balancer back on, use the bolt and washer if it is long enough, if not use an installer. It sounds like you had your flywheel off at one point, did you put locktite on the bolts when you reassembled everything?
J
johns94gt
Yea i figured leaving the belt on before breaking the bolt loose. Now when reinstalling it how do i keep it from turning the crank? Yes i installed a new clutch, flywheel, TOand pilot bearing back in april and i cant remember it i did or not but i did torque it to spec if i remember correctly 83ft lb.
framda
Naples, Fl.
I would not put loctite on the crank bolt, but that is opinion, others will disagree. You do need it on the flywheel bolts. Putting the crank bolt back in is the reverse of taking it off. put it on as tight as it will go, put the belt on it and finish torquing to spec. Put a new crank seal in unless you just changed it. put some RTV on th keyway of the crank. Not too much RTV because it can get in the oil pump.
det_riot
Dearborn
^pretty much nailed it. doing your balancer should be like a half hour job at most. When I replaced mine over the summer it was a matter of unbolting the crank, using a puller on the part of the balancer still attached to teh crank, lubing up the shaft with some engine grease, and putting the new one on, running it down with the bolt and washer and I was good to go. As far as which balancer to go with, I just got the ford racing one from summit and have zero complaints.
massacre
My stock bolt was too short to use it to install the balancer, had to use the install tool. Also, Ford says the stock bolt is TTY 1-use only.
I know guys who have re-used them with no problem, but I decided not to risk it and went with an ARP crank bolt.
Since I have cast crank with an auto and high-stall converter, I went with a stock Mach 1 auto balancer.
-my .02
Paul
Unless you have a good, small impact wrench with a short impact swivel on the end, and you can pull the balancer from underneath, you'll need to be removing some stuff (fan, radiator, etc.) to get it off. That's been my experience anyway.
Balancers can be a real bitch. I don't take my car to shops, but this is one where paying someone $60 to do it makes sense. (at least for me) Of course, I'm lazy, and time is at a premium.
Paul.
det_riot
Dearborn
FWIW, I didnt pull anything when I did my balancer, and I did it all from the top of the engine. Broke the bolt loose, broke loose the crank pulley bolts, took off the belt, took off the crank pulley, and just did the rest of it with the autozone crank puller. I just used a 1/2" drive socket and rachet and took my time with it.
J
johns94gt
Det_riot i might just give a whirl before taking anything off and if i run into any problems then ill redort to that!!! Forgive me for sounding stupid but im not familiar with abreviations, whats "FWIW" mean
det_riot
Dearborn
haha no worries, it means for what it's worth. I thought about trying to pull it off and put it on with the impact but it was too awkward to fit down in there so i just used the rachet
det_riot
Dearborn
You'd think that but it does. Mine had the rubber peeling out but it was still in one piece. luckily it waited to give out until i was in my driveway but there was definitely a noticable difference one i put the new one on
det_riot
Dearborn
when it was out out and seperate. i started my car and the whole thing shook violently, so I killed it immediately and checked that out first and my weight had actually seperated from the hub. If your rubber is starting to come out then you should probably switch it out just for piece of mind that it isnt gonna seperate while driving.
2002BLGT
Bedford VA
Did yours cause your car to vibrate?
It can definitely cause a vibration and the 94-95 cars are very prone to the balancers going bad after 50K miles quite often , I replace them on cars alot of times when they come down for a dyno tune because when I start checking things I can see them wobbling like crazy .....If you need help installing it I am down in Bedford VA so just give me a shout , cell is 540-875-8722
framda
Naples, Fl.
^ will do man!! Does anyone know what size bolt that goes through the H. Balancer?
If you are needing a replacement get it by application from someplace like Ford or ARP. It needs to be of the right grade. Don't forget the washer.
