Hesitation and backfiring
cobra4202
My 95 cobra Is having a problem , I'm not shure what's going on.
It will run perfect fo a couple of days, then it will start to have poor throttle
response while driving like a very bad hesitation and an occasional back fire.
Sometimes at idle the RPM's will jump to around 1200 and I can hear air
being pulled in by motor. I pulled the codes there were several for oxygen
sensors and a couple for EGR.
Any one have any ideas?
ivan12
Re: 95 cobra needs help
Bad or dirty MAF sensor. Try cleaning out the sensor with denaturated alcohol (I believe that's how you spell it)
paintslinga2010
My car has done this a couple times. Once after i cleaned my air filter and put new oil and another after i drove through puddles. Both times i solved it by cleaning my maf with maf specific cleaner.
2002BLGT
Bedford VA
sounds like a vacuum leak , post the actual code numbers you got from it , they will point you in the right direction to fix it for sure
C
cobra4202
The codes are: 172,173,181,186,189,327,334.
I cleaned the MAF, EGR valve, air intake temp,
it has improved but still not where it should be
birel21y
Sounds like the computer is running the IAC fairly open, and is trying to compensate for a rich A/F mixture. Id try the O2 sensors.
2002BLGT
Bedford VA
What mods are done to the car ?
C
cobra4202
The only mod's are a pro- flow 70 mm mass air kit , under drive pulleys and a catless h pipe
C
cobra4202
:eek:ccasion14: Sorry to take so long getting back, I finally
swapped the o2 sensors. She is running great!
Once again thanks for all the usefull feedback!
