HID question
MustangMan00
hey i just got my HID kit and they have pictured in the sceumatics a relay, it didnt come with one....do they hook up and their fine? i figured everything out and the bulbs go to the ballasts and everything then theres a wire with 2 fuses that goes to the battery, id think that would be fine without a relay......people with HID's do you run relays? how is your setup
thanks a lot
97WhitePony
you need the relay ( i assume) to give the ballasts direct power from the battery. Therefore, you would tap the power wire to either headlight and put that to the signal post on the relay, run the main power for the relay to the battery (20 amp fuse inline) and then out to the ballast... i would run 2 relays though, one for each ballast... I have the stangmods HIDs and they are direct plug and play WITH highbeams as well... good luck!
MustangMan00
and they came with relays? i got em from another company and they have high and low beam, and a black box which i was thinkin was a relay but it showed that plus a relay....i think itll be fine without them tho, if not where would i get a relay that works? radio shack?
MustangMan00
heres a pic im super confused now
this is the wiring harness and i labled everything....there is only one socket to plug in where the old bulbs are, does the other one get taped off?
reivaxtorres
yup, the other stock light socket gets plugged, you dont need it anymore. plug the wires into the battery, plug the light socket where it needs to go, tape off the other plug socket, plug in the harness to the ballasts, and plug in the HID bulbs into the ballasts, then just plug the bulbs into the housing. all done!
MustangMan00
nice anyone know about fogs, they jsut have ballasts and the bulbs, no ground wires or wire to the battery, everythign should work right?
reivaxtorres
the fog light kit will be identical to the headlight kit. they will still include ballasts and everything, wiring to the battery and grounds.
96GTPlanB
