hit a bad bump and dam!!
justinschmidt1
have you tried jacking the wheels off the ground and trying to shake them back and forth to check for play?
Tony
Tony
ohio
no but thats what im bein told to try, i havent had time today to do much with it but tomorrow im figuring this shit out!
justinschmidt1
oo...ya...if its shaking like that and a wheels not bent, something is probably loose or broken....
Tony
Tony
ohio
i hate this type of shit! like 6 fn things ya gotta tear apart just to see what u have to go buy and replace, lol! awesome!!!!
Locomoco
SinCity Las Vegas
Okay I have a few questions to ask first off is the vehicle shaking only at certain speeds or is it doing it all the time ? 2nd is the vehicle pulling left or right ? Any and all info is helpful when trying to figure out what's the problem. Kind of replay what happend ask yourself what speed where you going did it feel like the vehicle bottomed out ? Reason I ask this is because most of the time alignment problems such as tie rod ends don't cause a shake unless the have more then normal play and control arms for the most part won't cause a shake unless you blew out the bushings even then it wouldn't be bad. Now as far as a strut well that can cause a shake if it popped the seal inside the unit and it's not doing its job. The number one purpose of a shock or strut is to keep the tire on the ground so if it's blownen it can cause a tire hop which will cause tire cupping. Now it could be possible that a hub bearing could cause a shake because the hub took most of the impact, I'm leaning towards a possible tire or rim issue or bearing, if the vehicle started pulling I would say yes maybe tie rid ends, control arm or even rack but being in the automotive field it's not a common issue when it comes to a shake. I'm interested in hearing what you find keep us posted
Tony
Tony
ohio
it starts at about 25-30 mph and gets worse as i accelerate. i hit a raised bump going about 45 mph and went onto the freeway and had to pull off cause the front end was shaking so bad! the bump was pretty big! the wheels werent the problem cause i have replaced them both with the spares that i had from what was on my rears. it doesnt pull in any direction just shakes pretty bad, i can definitely feel it in the steering wheel!
SRT Handz
You hit one of these?
Tony
Tony
ohio
^that fn thing is way too detailed! wrinkles and fn veins dude! i want my mommy:(
Make sure you send the bill to the City/State. I had a issue with a pothole and a bent rim and I made the township I was driving through pay for my new wheel and tire due to poor road maintenance. Took some time but I got my money.
Tony
Tony
ohio
lmao! i just got off the phone with my old man and he said the same thing! they had to pay for his ladders and rack cause of bad road conditions, they fell of his truck! they paid!! thanks dude!
miss2slocoupe
Canton, Georgia
wow i never knew you could do that... thanks for the heads up if it happens to me
96GTPlanB
