Hmmmm here we go again
Late4Work
Took the tune off and noticed something odd.... While in 5th gear if I let off completely, I feel a clunk..... Only happens in 5th, any ideas?
greenscobie86
The Big Apple
Ujoints? Where does the clunk come from?
Could be old and sloppy trans/engine mounts that rapidly move as the stress/load is taken out of the driveline...
Late4Work
Late4Work
Well the funny thing is that it didn't happen while the tune was on it, and if I push the clutch in before letting out all the way on the gas, it doesn't do it
Late4Work
Late4Work
I haven't checked, but why would it only do it when the tune is off?
chris91
Cincinnati, OH
Yeah sounds like a weird coincidence that its doing it with the tune off. Throw it on some jack stands and check the u joints at the rear end. Youll more than likely notice some play. Cheap and easy fix though. :)
Nightmare
Cedarburg Wi
Probably the trans mount.....while you are checking that out, check your shaft....How many miles do you have on it?
sn95jones
Arlington, Tx
Mine's got 89,100 miles and mine does this shifting from 1st to 2nd under normal acceleration. I have a tune though, and a short throw shifter.
Late4Work
Late4Work
I have a short throw.... I'm just trying to figure out why it does it without the tune on it
chris91
Cincinnati, OH
Did you throw the tune back on it to confirm it isnt doing it with it on as well? Also you sure it is only doing it while in 5th? Try driving at a steady speed in another gear and then snapping off the throttle.
Nightmare
Cedarburg Wi
The tune should really have nothing to do with a noise in a manual trans.....The only thing that I can think of is that with the stock programming, the engine is idleing a little roughter, transmitting sound and vibration through the trans and up through the short throw (since I am willing to bet that yours dosnt have any isolators). When the car is running on the custom tune, the engine is running smoother and the noise and vibration is decreased.
Some things I would check to "test" out this theroy:
Trans mount
U joints
Depending on the shifter you have, the tightness of the bolts/alan screws holding the handle on
If all of these are good/tight, see if it makes the noise in different RPM ranges..That will help varify the vibration question....also see if it does that in gears 3-4 in those same rpm ranges.....I dont think you have an issue with the trans its self, maybe the tension on the clutch cable, but not something that is internal to the trans.
Late4Work
Late4Work
There is no noise, I don't know where that idea came from..... I have tried it in 4th and it doesn't do it, it does idle a bit rougher though...... Can't throw the tune back on it cause it's sold and gone
Nightmare
Cedarburg Wi
When I say noise and vibration, I would categorize a clunk as well. Unfortunatly, with out being there, I can only speculate. Does it clunk on high RPM or low RPM? I still wouldnt rule out a drive shaft......I had a Ujoint issue present its self a few days after getting gears done in my old 88 gt, and I have heard many clunks in 5th on my ranger letting off of the gas prior to getting the whole shaft rebuilt.
