Hood liner really necessary?
Photonfanatic
South of DFW TX
I want to try this but its 90 freakin dollars. People I've talked to on my chevy truck site say it cancels nearly all engine noise that you can hear from the outside. However there are a lot of other things to do to the car before its so far along that I'll spend $90 on a hood mat lol. Cascade is a very reputable sound deadening company.
http://www.amazon.com/Cascade-VB-TS-Thermo-Acoustic-Hoodliner-13-9/dp/B00067IUZ4
As an Amazon Associate we earn from qualifying purchases.
I have that stuff on my tranny hump to keep down heat. It blocks heat well but is not much of noise barrier honestly if anyone said they could actually hear the difference they were full of it. There is not enough mass to that stuff to really stop noise but does a great job on heat.
Cpotts13
Biloxi, MS
To the OP, my hood liner to had seen better days, so i washed it off with a hose let it dry thoroughly and spray painted it black with engine enamel :) Still looks good after 2 years!
Photonfanatic
South of DFW TX
You have the exact same product I linked? Cascade brand with the two different layers of foam?
Photonfanatic
South of DFW TX
if that works both as a thermal block as well as a sound damper then go for it but I think the cascade is just a typical mass damper/type of material. It will take longer to heat up but it should not reduce the temp much after it is hot. The fiberglass stuff I linked too does not get hot and reduces the temp but will not do anything for noise. I think the only way to get both would be to do a layer of both if you wanted but in my case it was just the temp I was worried about.
GT Rob
Houston Texass
Took mine off and now the hood needs to be painted. So if its in good shape leave it on our replace it
