How does these non EFI covers fit
racing4funn
I was told these black motor sport covers arent EFI and on top of that not may covers fit a 94 - 95
Yes I lifted the picture from here to study it but cant remember who from to ask how.
Paul
They'll fit with the intake spacer you see in that picture. Your EGR will need to be lengthened too. Do a search and you'll find what you need.
R
racing4funn
Im running a BBK long runner intake that sets up a good bit and no EGR. I like the covers but dont want to spend the money on something that I cant use
modo
Philadelphia, PA
what paul said...
issue is typically the throttle linkage bracket hits. i also believe on the sn cars your alternator is closer to the pass side cover which you might have to massage either one.
late 92 and all of 93 valve covers have a lot more clearance inside. mine clear my 7/16" rocker studs (big) and 1.6 scorpion rocker arms
BlkoutGT
MO
I put ford racing valve covers, similar to the ones in the pick. They cleared the alternater but i had to unbolt the the alt so it could slip in. Its a tight fit.
RossA81
Monkton, MD
I run the ones in the picture. Took a 1" spacer to make them fit. Had to cut part of my throttle cable bracket off(the cruise control part) I am running a fox tb setup. My stock hood rests on my intake but closes(liner is removed)
They look cool but not really worth the hassle.
Ross
Suspect
ATL
its mine. easiest way to make em fit was going to a fox tb. just ended up doing it sooner rather than later.
R
racing4funn
by Fox tb do you mean one the dosent have the bent towards the front corner? If so Im using the BBK long runner intake that the 70mm tb bolts to that. So I could run those?
R
racing4funn
