How much would pi heads and cams help me?
justinschmidt1
Well, Im debating whether or not a pi head/ cam swap would be worth it for my car. I have pretty much very bolt on so thats why I was thinking that the heads and cams would help me a lot more than just a normal pi head swap.
I would imagine that the long tubes,o/r h pipe, tb, plenum, intake would gain a lot more on a pi motor compared to my npi so I was wondering if anyone else had a similar swap.
I would like to be mid 13s atleast if I do the pi swap. I currently have ran 14.1 at 98 with 2.1 60
anyone here swap npi to pi with a lot of bolt ons?
I plan on doing mine soon too. I think I might go to the junkyard for all the parts (intake, cams, possibly heads depending upon how much it all cost). Thats probaly the cheapest place to get them.
reivaxtorres
i too had just about all the bolt ons i could have minus the headers, and i noticed a huge difference in my set up. at first i did just the PI intake and felt a difference in the top end. then i did the PI cams and felt a bigger difference in the top end. finally did the PI heads and felt a significant difference in the top end as well, along with the midrange. the bottom end felt like it suffered a little, but barely anything. as for #'s, before i was able to pull off 2.2x and 2.3x 60' times and 9.2x-9.3x @ 72/5mph in the 8th mile. now with the added weight of the IRS (about 85-100 lbs), im at 2.1x 60' times and 9.0x - 9.1x @ 77-79mph, all on street tires and no drag racing suspension. have no idea what it runs in the 1/4 mile tho, havent taken it out in a long time.
DropTopPony
South Jersey
You would get a nice bump with the stuff you have, it would enhance the power you'd pickup from the cams/heads/compression.
J
justinschmidt1
Im just weighing my options...I mean if I went with a pi head swap and pi cams I probably would be mid 13 to low 13 at best. I figure I might as well save up and go with some sort of forced induction. Even with the npi heads I bet i could make almost 350 Rwhp compared to far less than 300 with the pi swap..
I would really love to go turbo....turbo stangs make some amazing numbers.
