How to adjust UPR quadrant and FW adj?
9646gt
First post here guys :) I'm on some other forums also as either 01mggt or 9646gt. But anyway, I am back in a SN95 again finally and It's a 95 Gt that the previous owner put a UPR quadrant and firewall adjuster in when he replaced the clutch. This is the first time I have had these installed on a car. He has the clutch where the engagement point it almost at the last like 1/2" of travel up top and the clutch pedal height also seems much higher than on my new edge I had before and even my 96 I had. How can I lower the pedal height and change the engagement point? It would help if I had ever installed one of these, but I haven't so have very little knowledge how these parts work. thanks for any help!
ProKiller
PA
just twist the firewall adjuster till you get the desired engagement point. to bring the point more in the middle, turn it counter clockwise
9646gt
Thanks ProKiller ! And the pedal height? I might be able to figure it out on my own once I actually get the car here and can look under the dash :)
