How to remove passenger fender?
BladeX10
Going to swap out fenders on my 94 and need some help on how to remove it. Any help would be appretiated.
CompOrangeSN95
North Jersey
If you pop the hood you will see bolts holding the top of the fender on, there is also bolts on the bottom behind the front wheel, i'm not sure if they are under the side skirts or not, my car doesn't have any. And if im not mistaken there is a bolt behind the headlight as well, pull those and the fender should come right out.
switch96
There's a couple bolts you have to open your door to get to. Look through the crack with the door open and you'll see them. There's also a bolt or two holding the fender to the front bumper right in front of the wheel well.
