How To: Replace Shocks
cntchds
Jack car up.
Put jack stands under the torque boxes in front of the lower control arm mount.
Lower car onto the stands.
Support the axle by the diff with the jack at near full suspension droop.
Remove the top retaining nut. (various sizes depending on brand of shocks. Stock is 15mm. Tokico is 15mm. Koni is 17mm.)
Remove lower retaining bolt and nut. Bolt is 15mm. Nut is 18mm.
The shock will now be removable. Just wiggle it out of the shock mount.
Repeat for other side.
Installation is reverse of removal.
Follow these directions and you will be done in a half hour. Follow ones that instruct you to take off the brakes, and you will pray to be struck down by lightning.
Happy modding.
C
cntchds
Which is precisely why I made this how to. I hear of people bringing their car to a shop for a shock replacement, and think "seriously? You could do it in the same time it takes them to write an invoice."
Struts on the other hand... Not my favorite thing to do, though the write up will be here within the week on how to do the struts.
sn95gtvert
Spokane Washington
damn i should have takin pics the other day, i had my drivers side one blow out and replaced it.
its not that bad as long as you have some air tools. only 2 bolts and the top mount.
Venom351R
Maine
I just did this over the weekend and was going to write up a how to on it but I see one is already here so I'll just throw in some pics. These are for Strange 10 way adjustable shocks the install is the same but I'll also post pics of the correct bushing configuration to use on the shock.
Place the car up on jacks stand or a lift.
Remove the liner in the trunk exposing the shock tower and remove the top nuts.
Remove the lower bolts on the shock
Place the new shock into place
Tighten the top nut until it compress's the bushing
All done, lower the car and enjoy your new shocks
For those doing the strange struts (and I'm sure its the same for others) this is how you do the bushing configuration.
Place one the cap on the bottom, the cap has a hump on one side, that hump needs to be facing down
Place one bushing on w/ the raised part of the bushing in the center facing up. Take the second bushing and place it so the raised section in the center is facing down so the raised sections are facing each other. Place the second bushing and cap on once the shock has been pushed back up through the shock tower
Place the second cap on the top with the hump facing up.
Yeah doing shocks on a stang its easy.
Nice pics venom, seems like the bushing configuration is the same
well atleast it was on my Konis
Venom351R
Maine
yeah that's the way they were on the Koni's I took off. Probably universal for every shock out there.
C
cntchds
Just as a heads up the bushings should not be compressed. The cap should be snug against the bushing, but it should not be misshapened. At least that is what the instructions my Konis came with said.
