TRUUBLE said:If slomaros weighed 1500 pounds, you would never see any other kind of car at the drag strip.
DFG_Pimpin said:cheapest way is to buy a tow strap and hook it up to a 10 second car.... :hammer:
Mike. said:Cheapest way is definitely nitrous, some suspension, super sticky tires.
Even thats prolly not going to be that cheap. Cheap and "in the 11's" is not the most friendly combo.
realitygt said:Like I said, how would you guys do it, if you were going to get down to 11 seconds.
WyoTechMSA said:realitygt said:Like I said, how would you guys do it, if you were going to get down to 11 seconds.
We ALL told you, nitrous small black with an auto and slicks but you said "No I wanna go big block with a 6spd and blah blah blah." Even if youve changed your mind now and are going with a 383 and MAYBE nitrous theres still that little issue in the fact that the car isnt even structurally sound.
FUK_N_JUNK said:Push it down a 10sec. mine shaft :rollinglaugh:
No seriously, finally something I HAVE DONE and can contribute to...
I'm gonna guess it's a 3rd gen car?
1st thing you want to do is get rid of the 10bolt cause it will snap 1st time out (you got a 7.5, your buddy has a 8.5)
Build a nice SBC ( I did mine for under $3K)
Use aftermarket LCA/Torque Arm/Anti-roll bar
Gut the car
27/11.5/15 Mickey Thompson ET Streets
SUBFRAME CONNECTORS ARE A MUST!!!!
SPray a 150 shot to it... walla your done.
I built my car in 6 days in my garage last year in April (didnt have a car at the time to drive for summer racing) and it did a best of 10.90 @121...... 1.65 60's though :'(
Im getting all the machine work/ hot tanking done for free, and all the internal parts for wholesale price(like a meziere water pump for $45)uncltrvlnmatt said:There is no cheap way to get into the 11's. Your car is big and heavy. If you get it down to 2500lbs be very very happy.
You will need to bore it, port it, forge it, cam it, balance it, single plane, and put a big a$$ carb on top that is not to big, plus all the little things that will need to be replaced like, distributer, coil, valve springs and retainers, rockers, bearings, rods, pistons, rings, oil pump, miscelaneous hardware, machine shop work, like boring the cylinders, opening up the oil passages, balancing everything. That will cost you more than 3k, alot more.
As far as the trans goes, dump the stick, they are to inconsistant. If you miss a gear your engine is junk. Get a power glide.
The only cheap way is to spray the piss out of it.
My s-10 witha blown head gasket was running 11.76 @113.... you should be well into the 11's with a good 60'...uncltrvlnmatt said:You did not say you had a cheap way for parts and labor, that makes a huge differance in costs.
Miss a gear engine go boom. Big blocks don't like big RPM's, to much mass to move. Most don't like going over 6k, be smart enough to use a rev limiter.
Take it from somebody who used to drag race a 4spd. I ran a 1968GT, 428CJ, with a top loader 4spd. I went through 2 clutches a year minimum. My car was very capable of running very low 12's if not high 11's. I had 2 major problems. 1) 4spd, I was very inconsistant, and never really got it down pat. 2) Gears, I had made a poor gear choice.
My best time was a 12.58 @ 113mph. My speed was there, but I lost alot of time due to poor shifting and hitting the rev limiter in or just before the speed traps. Between the 2 problems I definately lost 1/2 a second.
I let a guy drive it who had been running a stick for years and he ran a 12.33 @114mph. He drove the car one time only. If he was familiar with it he could have been into the 12.20's. This guy was good, he made a 4spd car sound like it had an automatic trans in it.
