I have been studdering..(Update 3/14)
Re: I have been studdering..(Update 1/4)
can you be a little more specific. size, color, exact location
T
TheNatster513
It comes out of the firewall on the passenger side it's black and maybe almost triangleish. Rather large in size like 2in at it's biggest size, can't find where it goes because it only reaches maybe 4in out of the firewall
that's what you plug the code reader into.
It should have a cap that's attached to the shock tower.
Win
Kennesaw, Ga
Yeah If it is a Rectangle maybe 2" x 3" that is the EEC test port
T
TheNatster513
So it's not anything? I didnt have much time to look, but I'll more tomorrow.
there shoud be another single wire plug that goes with the eec plug
T
TheNatster513
^it does. i put a new ignition coil on.. and it runs better but still stutters.
det_riot
Dearborn
Whens the last time you replaced the pcv valve/screen? Any vacuum leaks?
T
TheNatster513
should be no vac leaks, changed the pcv valve when i put new intake in. didnt know about the screen though?
could it just be the bigger intake with the stock injectors?
T
TheNatster513
det_riot said:
Stock injectors will hold their own for a little more hp than what you're pushing.
Here's a little more about the screen
http://www.allfordmustangs.com/forums/5-0l-tech/11383-clogged-screen-under-pcv-valve-oil-leaks.html
i meant more on the i have to much air for the stock fuel ratio. thing.
rz5.0 said:
sure you dont have a vac leak in your dash. have you had your car tuned yet.
i dont think i do. how could i check? i have not had a tune. but im going to get a chip and see what happens.
Win
Kennesaw, Ga
I would say just replace the Dist. Or replace the PIP sensor in the dizzy your choice on how much you want to spend. It seems you have done a decent bit of everything else.
T
TheNatster513
phantom09086 said:
Have you checked the batt to see if it still good, you can do this with a load tester.
battery was replaced last year or two, should be fine.
already replaced the dis. I'll look into the pip thing.
