I have been studdering..(Update 3/14)
TheNatster513
This summer I put the gt40 package on my car with a light cam (if you need specs I can get them). But it studders.. A lot. The weird part is the stuttering can be worse, not there, or lightly. Anyone have any suggestions? It's getting really annoying. It can go away when I romp it, but it Boggs down for a bit then just unleashes like some one flipped a switch? And other times it will do nothing? It does better on premium.
Win
Kennesaw, Ga
Re: I have been stuttering..
What is your timing set at? Have you checked your dist for water condensation? or a coolant leak around your thermo housing?
T
TheNatster513
it should be at stock timing. I'll ask the mechanic sometime. Where would I check dist for cond? No leak around thermo.
CC'S95GT said:
check that your coil isn't breaking down
what do you mean coil?
Re: I have been studdering..
Ignition coil.
When a coil gets old the insulation around the windings used to increase the voltage starts to break down causing internal shorting. which gives you a missfire or no fire at all.
T
TheNatster513
CC'S95GT said:
Ignition coil.
how do I check this?
Your haynes manual can tell you how to do it.
You can get a new one for less than $40
T
TheNatster513
Re: I have been studdering..(Update 1/4)
Update: I have not tried the coil. But I have a new development. I started my car this morning and let it warm up for a few min. I left the heat off to see what would happen. I started to drive the car and it drove perfect. So about half where to where I was headed I thought I would see what happens if I cut the heat back on. Studdering is back. What would cause this?
phantom09086
Germany / Maryland
Take it off and spray carb cleaner in it to get all the carbon build up out. It works sometimes, But most of the time you have to buy a new one. Rockauto.com sells them for a good price.
Win
Kennesaw, Ga
Is it only the heater or was it the whole fan and AC system?
T
TheNatster513
Idk win. Its like 40 here and I clicked on the heat and it started stuttering bad. I did feel it very lightly before I clicked on though.
Win
Kennesaw, Ga
So the fan was on already? I am thinking possibly check your grounds again.
T
TheNatster513
Idk if the fan was on. I'll see what I can locate today.
T
TheNatster513
I found a big plug on the passenger side of the engine comp that is unplugged any idea what this is??
