I have been studdering..(Update 3/14)
T
TheNatster513
Re: I have been studdering..(Update 1/4)
I have a new thought! I need some pics of 94-95 TB to look at your idle screw. Or does anyone know where it's suppose to be at? I think my idle is up with is giving me a false timing.
Then do a base idle reset.
I think the idle bleed setting is supposed to be 2 turns from the bottom or less. and there is also a throttle blade setting.
search base idle reset and you'll find it
BlackBeauty
jumpriver wisconsin
kind of along the same subject here guys, I have close to the same setup as him and after installing a trickflow heads and intake with an E-cam and I have a stutter at 2500rpm. Ive set my base timing at 10 degrees and later to 12 with premium. Could any of this have to do with our cars not being tuned?
T
TheNatster513
Re: I have been studdering..(Update 2/21)
I had a friend look at the timing. He said it was at 25 degrees... Ouch. We dialed it back to about 16. (I would like to go lower) runs much better but still stutters a little. Chip coming this week.
T
TheNatster513
The chip is in and I dialed the timing back to about 14 (guy who made can told me to put it there) Still freaking stuttering!!!!!!!!!! What Is this? It is not as violent as before, but it is more often??
Win
Kennesaw, Ga
Have you checked the plugs since all this crazy timing ??? Have you also checked your wires to see if your arching anywhere?
T
TheNatster513
it helped. but was not perfect. i dont think the problem is in the computer. i think its electrical.. but i dont know where.. almost everything has been replaced in the engine that has to do with the spark. ill check ALL my plugs sometime this week to look for anymore clues
