I need some suggestions please
pirotec354
Ok so im going to be getting some new rear suspesion here soon and im not sure what to get. I need something that is going to give me some good traction at the track, b/c right now all I have is some eibach drag springs, upper and lower control arms and some gas adjust shocks. The car is all over the place from the line. I know I need tires too, but i wanted to do the suspension first.
So i guess my question is, what should I go with? Should I get a rear coil over kit or some of those kyb adjustable gas shocks and keep my eibach springs? Which is better for the track?
Thanks guys.
-Justin
94kingcbra
This could be torque steer from worn clutches in your limited slip differential. If you want a true straight launch, you need a locker, and some good axles. Another thing that will help your launch is to eliminate any drag on your front coil overs on the initial go when the front end lifts up. Make it as easy as possible for that shock to be easy coming up but stiffer coming down. This way the front of the car will lift up easier and faster which will in turn put it directly to your wheels. Good Luck!
