I think my t-5 is going out
CC'S95GT
Hampton ,Ga.
when ever i pull it into 4th i get a slight grinding sound. it happens when up shifting or down shifting. nothing in anyother gear, so it's not the clutch. i think it my synchros. i just need confirmation from ya'll. does anybody have an extra t-5 sitting around, i'll take a t-56 if that's all ya have.
Paul
Probably. Over time the friction material on the blocker rings (synchros) wears off and they are unable to synchronize the speed of the gears appropriately - so you end up with a grind going into gear. Third gear in my '95 daily driver is doing the same thing right now. A rebuild would fix this. In the meantime, you can just baby it by taking your time shifting gears to allow the synchros a little more time to work.
Paul.
Mine did that with 2nd, but now its gotten to where I have to skip it. Not a big deal with my 4.10s, but annoying none the less. Going in the shop sooooonnnnn though. Like tonight or tommorow soon. :D
Steven
SC
rebuild the trans yourself. Its well worth the effort. My 95 randomly grinds, randomly meaning it typically doesn't, 3rd and 4th mainly when its cold.
1quk50
it does it in 4 th because thats the 1:1 ratio.. mine did that is it whining?
if so the bearing could be going out..
if you ever plan on modding go ahead and buy a 400 hp 375 tq kit from D&D performance.. comes with everything but youll need a fox body bell shift fork and the bearing retainer.
CC'S95GT
CC'S95GT
Hampton ,Ga.
thanks guys. that's pretty much what i thought. good luck to ya'll with your tranny probs too. and i don't know if i have the skills to rebuild it myself. but i'll give it some more thought.
1quk50
its not that bad just time consuming... i rebuilt mine by my self.. D&D performance has a step by step directions on their web site! plus their about the cheapest around.
Prdbyford1
probably a combination of the blocker ring, slider and the gear on the input shaft. Had the same problem with my second gear and third.
Win
Kennesaw, Ga
I pulled my tranny out myself in about an hour with just the car up on jack stands then i layed under the car and just poked around for another hour :) You can find a lot of tranny's in the classifieds Or on your local craigslist.
CC'S95GT
CC'S95GT
Hampton ,Ga.
i've already had the tranny out when i bought the car to r&r the clutch. i thought i had a deal on a tranny off craigslist but it was out of a fox. damn
95 svt cobra
Mine did that for a long time, i babied it and when i started to contemplate my T-56 swap i decided to let er have it, shortly after that it went out. I think as long as you dont abuse it you should be ok long enough to save up for a rebuild or a T-56 swap. I recomend the T56 swap though hehe
Win
Kennesaw, Ga
DESERTCOX05 said:
with the 4:10's a t-56 is almost a necessity. but with a wife and kids it's prob a pipe dream
I have even heard Some people over at SVTP even running 4.30 4.56 and i think i saw one or 2 that ran a 4.90
MikeF
i have 4-10 with 5 speed and a v1 the gears do go quick.but its not my daily driver but works out fine for me
R.C.
