ignition coil plug
94yellowgt5.0
does anyone know where i can buy the plug that goes into the bottom of the ignition coil, when i changed the ignition coil a couple of weeks ago the part the holds the wire into the plug broke and now the wire wont stay attached to the coil. anyway is this a part that i have to buy from ford or can i get one at an autostore?
dsg gts
go to the junk yard snip off the part. go home turn it facing you get a small screwdriver look inside of it. you'll see the tabs that hold in the wires. carefully pull the tabs away from the wires then pull the wires out the back. do the same to the part on your car but don't cut them. slide them into the plastic piece until they click in. put some electic grease on it. plug it in.
MustangMoser
my parts dept does not show a listing for that pigtail. junkyard or rjm like the skipper says
94yellowgt5.0
hey i've got a stupid question but would i get the pigtail or the connector with terminals because all i need is the plastic harness that goes into the igntion coil with the wires that go into it?
