I just picked up a set of the Eibach Blue Prokit springs, supposedly they are the roadrace/autox set up. "With progressive spring rates of 702/850 front and 199/257".
I've never seen or heard much about these so I figured why not. I've had the Steeda sports and a pro kit in the past.
What I want to do is set the car up for very abusive street driving and probably a driver's ed day or 2.
I do not care about teeth rattling rides as long as I can still hear the radio, I only drive 5 miles to work.
I'm looking into either the bullitt suspension kit minus the springs so some shocks in the $500 range could substitute this.
Should these be run w/ or w/o the isolators to get the most out of the springs? If with iso's in, should I use the Poly ones or get stock replacements? I really don't want to dumb down the spring rates.
I will be running on 275's up front and 315's on the rear, brand to be determined at a later date but probably something similar to a KD or KDW.
What supporting mods do I need? (suspension related, drivetrain stays stock)
Rack bushings? Offset?
C/C plates or fox length struts?
Removal of quads will probably be required to fit the 10" rims so what LCA's? Spherical w/ rubber on the axle? Stay w/ stock uppers and upgrade the housing bushings, but to what, so much hype about poly being binding that I'd rather go to spherical and live w/ the noise than end up w/ wheel hop.
I have subframes on order along w/ 03/04 cobra front control arms.
thanks
thanks
