Injector Size
CanaryGT
Phoenix
I wanted to start a thread to just simply ask questions about Injector size.
I have a completly stock engine and I am going to be running say at most 12 Lbs of boost.
What size injectors do I need and Why?
My buddy has a built 347 stroker and he only uses 30# in his. He is all N/A....
Please someone shed some light on this....
S281 #39B
Hope this helps,
FORMULA:
(horsepower X .5 (for N/A) or .6 (for power adder) ) Divided by (No. of cylinders X by 85% duty cycle)
The proper injector for this application would be
(350(hp) X .6 = 210) divided by ((8 X .85) = 6.8) = 31 lb injectors = 30 lb injectors with no room for improvement
19mustang95
30lb injectors wont handle a blower at 12lbs of boost, if that is what you were trying to say.(not sure)
quickstang_1994
Cross Anchor, SC
the answer was 31 and in the old day when 36's were around they would have been used. and yes they will Saleen uses 30's on their SC cars just saying, but I wouldn't recommend it. I would still go with 42's.
quickstang_1994
Cross Anchor, SC
S281 #39B said:
Hope this helps,
FORMULA:
This is the correct formula to use.
Greggerex
Not just the old days! ;) I just got a set of Ford Bosch 36# blue-tops from Racetronix - there are still a few kicking around brand new (they were used in the 94-95 Thunderbird Supercoupes). They are going in the Stang tonight cuz my 30#-ers aren't doing their job.
And you can also easily get 39# injectors.
However, I agree with whoever said 42#-ers - they are a good place to start for a stock engine getting some boost. And according to the given formula, on a V8 they'll run out at around 475 hp (boosted).
rgs
they can get away with 30's because stock all their cars run low low boost
Greggerex
some injectors are different like the voltage reading are different(can't think if the word). plus ford blues are 24.
Ford also had blue top 36# injectors - I think they were a darker blue (leave it to Ford). :D
As for voltages, I believe all injectors accept a PWM (pulse width modulation) signal for operation - their flow characteristics may be slightly different, but electrically they should be the same.
Paul
CanaryGT said:
It makes more sense except why do you put in a higher multiplier for a forced induction car as opposed to a NA??
It has to do with something called Brake Specific Fuel Consumption. This is basically a ratio of fuel consumption to engine output. Basically, a naturally aspirated motor can make the same power with less fuel than a forced induction (turbo, blown) motor of the same horsepower output. In the formula above, you'll notice that Saleen put up a .5 BSFC for N/A, and .6 for blown. These are decent round number figures that can be used when calculating fuel injector requirements for an engine.
It is always better to "over-inject" a motor (within reason) since you can just limit the pulsewidth of the injector via the tune in the ECU. Very large injectors (e.g. 160 lb/hr) can sometimes be a bit difficult to tune for idle/drivability due to the very large amount of fuel dispersed in a very short time.
However, although 42s may be a little larger than necessary (not by much) for you application, it will easily be compensated for by the tune, and will allow you some room to grow if necessary.
Oh, and you never want to run an injector past 85% of its maximum duty cycle. That is, past the maximum amount of time it can stay open when spraying fuel into the intake manifold.
Hope that helps.
Paul.
quickstang_1994
Cross Anchor, SC
but its the signal that counts and the v8 ford 36's were bright red.
Greggerex
Wow, so Ford in all their wisdom made light-blue-tops (24#), dark-blue-tops (36#), red-tops (30#) and bright-red-tops (36#) - guess they ran short of colors! :D
I've never heard of the red-top 36#-ers... interesting.
Either way, like I said, the signaling should be the same. O0
Paul
The Ford 36s on my silver car are dark blue, not red.
Paul
Probably three different manufacturers that made them for Ford.
CanaryGT
CanaryGT
Phoenix
Hope that helps.
Paul.
It does, thanks!
96Mustang4.6GT
