installing narrow band gauge
BigTang
either front O2 sensor, it should be the grey w/ red or red w/ black stripe, tie it in on the harness side away from the O2.
the other way is to do it at the ecm but its sort of a rats nest to deal w/.
GDawg
I have a narrow band too but I've never hooked it up. I want a wide band.
GDawg
Paul said:
It makes for some fun cabin lighting. :)
That's what I heard right after I bought mine. So I'm waiting to get a wide band.
yea, i got it cheep off the classified section. I thought it was wideband. and i was like $50.00 sweet! (I thought they were like $100.00) so i picked it up, then found out that widebands are like... $350.00... so ... i got a gauge pod with 1 empty hole. a guage i already paid for, and a cabin in major need of some cool lights... LOL!
okay, so on the o2, can i run it to the sensor under the drivers side seat? or passenger side seat? or do i have to go out of the car, then down to the exhaust, to the o2, then splice it in? its it just splicing to 1 wire on the o2 and 1 wire for power?
It says "not to use a power element with dimmer capabilities, these will reduce your device's life span" where do you guys suggest? sub woofer wires?
GDawg
MustangChris said:
yea, i got it cheap off the classified section. I thought it was wideband. and i was like $50.00 sweet! (I thought they were like $100.00) so i picked it up, then found out that widebands are like... $350.00... so ... i got a gauge pod with 1 empty hole. a guage i already paid for, and a cabin in major need of some cool lights... LOL!
Sorry bro, can't help you. I've lost my instructions and have three wires tucked away disconnected. I can always go to AutoMeters website and get the instructions. My boost gauge is hooked up to my dimmer switch but only cause if I need to dim the lights, I'd like all of them dim.
my vacuum gauge is dimmer as well, but thats because its not a digital gauge. Ill look into installing it this weekend :-D
Paul
The instructions are readily available for download on Autometer's website.
thanks all, ill see what i can do... th reason i ask is because i looked at the ones that came with the gauge and they are just like "Plug it into the re-route-re-direction-blah-blah-anti-blah plug on the o2 sensor." (Pretty much junk i dont understand) my main question is: can I plug it into the o2 sensor under teh seat? or do i have to leave the cabin?
also, where should i plug it in for power? i dont want to plug it into the dimmer switch... what are my other options? :)
thanks fellas! :-D
GDawg
MustangChris said:
no suggestions on a power sorce with no dimmer switch involved? lol
Have you looked at any of the instruction manuals on AutoMeter's website? My instructions from them explained which wire was a dimmer wire and which was a constant headlight power source (only comes on when parking lights are on).
i looked and they are exactly what i have with the gauge...
which, are tricky (for us dumb people) to understand... I ran my vac gauge into the dimer switch (cigarette lighter bulb) and I have no idea where a non-dimmer switch electric run.
about all i understand from it is: Do not run this device into a dimmer switch, it will reduce the lifespan of the device.
anything on the sterio I can plug it into?
BigTang
use the key on power on the fuse block, basically the radio fuse. just get an add a fuse for that or get creative w/ the wire and you'll see what i mean. but thats all its saying to use.
Paul
Any 12v switched power source will work for power.
Have you tried google? I think I found out how to do this years back with it.
im looking into using the fuse block now... :) thanks fellas!
also, which o2 sensor should i use? before or after cat? i plan on using the drivers side, just to save wire... so... yea... lol
GDawg
You're making it harder than it is. If you go behind your headlight switch/knob... there are a bunch of wires hooked up to it. Your Haynes manual says that the hot wire comes into the switch and for headlights, there are a few outgoing parallel circuits out going. It looks like the Red/Yellow wire is the one that is controlled by the headlight switch before it gets into the dimmer switch. Page 12-29 of the Haynes manual.
