the5.ohh
The pieces that go around the windows and unlock/lock buttons. How do i remove that piece and how can i paint it? I'd like to do a gloss black. Mine are starting to show its age
I have mine painted to match the exterior of my car.....a perfect oem match. I would recommend just doing a plain black then clearing over it multiple times. I have seen too many painted parts flake off because they are "high traffic" areas.
This ^ I forgot to add that in my last post. I'd say 4 coats of clear, make sure to wait for the clear to flash.
My suggestion for that much clear ↓
first coat
5mins
second coat
10mins
third coat
15mins
fourth coat
15mins
If it was the middle of summer the flash time would be shorter but it's getting colder and the5.ohh you're in NY so I'm sure it's every bit as cold as it is here.
first coat
5mins
second coat
10mins
third coat
15mins
fourth coat
15mins
thanks for the write up man i appreciate it. maybe i'll save it for next spring. Its getting pretty chilly, no more t shirt and shorts, been sweats and t and skmetimes a hoodie. At night it gets into the low 60s, mid 50s easy. Only gonna get colder lol.
When you do do it, you might notice slight "circles" on the trim. This is normal. There is nothing that you can really do because that is one of the injection points that they used for the mold, however most of the time, you can only notice it if you are very close to it.
True, if anything it'll be noticed more since you're spraying them black but I seriously doubt it'll be an issue.
The best way to remove them for me that has worked, pop the upper tab out, hold it firm and give a quick jerk upwards, it pops out real easy, the 2 times I removed slow they broke tabs, I have parted 60 of these cars out and always pull them fast and never broke one since!!
