is there a way to monitor obd1 diagnostics on a phone/pc
I am sure we have all seen the neat things they have for obd2 systems but is there one that will work similarly for obd1?
95opal
in order to dtalog anything you need a wideband o2 set up. I use zeitronix but theres also tweecer and Anderson pms also.
I have a full set of aftermarket gauges to monitor everything from AIT to oil temp and the ability to datalog them with that system. I am toying with the idea of installing either a small tablet or a pc to do this and was just thinking it would be nice to be able to monitor and reset codes from it.
95opal
That's all fine and dandy but the most important thing to monitor is your AFR, Vacuum, Boost, Exhaust Gas Temperature, Throttle Position, 0-5 volt sensors , oil temp and alt charging can be done with a simple gauge.
lutter94
South Dakota
OBD-1 only reports codes, in a key on engine on (or off) scenario. I don't think you can check codes while driving down the road, and it definitely doesn't report any live data.
cameron57
Megasquirt has recently caught my attention also.
Sent from my SAMSUNG-SM-G920A using Tapatalk
I have no intentions of driving down the road while trying to pull up and reset codes. But there are a world of options open for streaming things as well as for things like this that if it were all hooked up and worked correctly would be nice and easy. I put the "work correctly" in there as I know its only a matter of time before the pc it bad/outdated and hopefully it will never ask me if I am sure when I shut it off.
Jerry santos
