is there any other h\c\i excpet PI for our 2v???
silver 4.6
Guest
I want to build this motor {or another 2v} when this one blows up... but what parts do I buy for it?? I haven't found anything excpet pi to put on the top end.. what else is there to make a fast 2v with??
I see that 5.0's have different setups... anything like that with 4.6's??
duff daddy
I have(had) just HCI on my car some very VERY basic bolt ons and very basic suspension, and i rana 12.6 with my ar several times.
silver 4.6
Guest
ive looked for trickflow stuff, either im not a good googler, or its complicated to find.
duff daddy
Its the Trickflow Track Heat intake then their new Heads, and Cams but when your looking at over 2k + at some places for just those heads,then say 500 for cams and the inktake is about 800 ish.... that's an expensive combo, you'd be better off buying the pi intake, some comp or MHS cams and heads either, pi heads and get them ported by fox lake, MHS, or get Patriots.
duff daddy
Its proven, it has been around for a while, its available so that makes it more economical to do.
vermilion
maryland
PI and trickflow are our only options for heads. i feel soon someone else is going to make heads for this engine variant. as everything else it takes time.
ThePope
I've seen excellent results with the Trick Flow 2 valve heads. When I get ready to build a engine, I'm gonna go with those heads as well with CMS cams.
duff daddy
silver 4.6 said:
how much longer is the 4.6l 2v going to be popular?
for ever, why are pushrods still popular they havnt been in a mustang since 95... I will never run a 4 let alone a 3v
McCloud
Johnson City, TN
I've got the Trick Flow heads, Track Heat intake, and CMS Stage 3 Turbo cams. The engine is almost put together and we should have it on the dyno in the next month or so.
