It's dyno time - finally!!
Dalamar
SLC, UT
Well, after much adu, my car should finally hit the dyno today to see what she'll do with the non-intercooled Rotrex on there.
The Grand Master Tuner there in Scottsdale swaped my fuel pump, injectors, and MAF.
ya know that surging idle durring open loop problem..... yea, it's the Maf.
We'll probably do a few other things after it's run.
Like: we're swapping the coil packs out for single coil over plugs, because Mr. Wizzard has figured out the coil packs loose spark at high rpm's because the packs don't have enough power to run down the wires at high rmp's. High rpm power fade..... hmmmmn.
There's another example of why I'm happy to pay the man, he knows what works, and more importantly why.
He's also probably one of the best tuner's I've spoken to. he retunes all aspects of the stock program, and doesn't just turn things off like a lot of tuners do.
We'll see what she put's down non intercooled, then I'll decide what to do with her next. :)
Lightning Struck
good Luck Jeff, hope it goes well for you. I have missed quite a bit on your car I think when I was MIA for a month and a half, you DO have a stroker modular right??
realitygt
hey after you get done dynoing, send me the rotrex and i'll dyno it here to see if theres a difference. my car is almost completely stock it'd be perfect. :p
Dalamar
Dalamar
SLC, UT
Thanks Javi, yes I've missed my car. especially since the weather is so nice now.
TY Brian, Yes I have a stroker mod. not to worry, it just sat for the last 2 months...
Paul - Rob, formerly with SVC is doing the tune.
Thank you BlueX
Dalamar
Dalamar
SLC, UT
The kit will fit right up to stock configurations once they're done.
that'd be the next step for them, see what it does on the stock motor
AaRoN said:
Can't wait.........
Me 2 :crazy2:
Dalamar
Dalamar
SLC, UT
whelp, there was some issues with the new maf and the placement of the blow off valve,
so he had to change that....
dyno is on for Monday.
Dalamar
Dalamar
SLC, UT
well, I'm off to Phoenix!
got a job on thrusday, check on the car on friday. I'll take pix. :)
