Just a short youtube vid i made of the turbostang..
94mustanggtfast
tht a nice car man. i was guna go with the same idea body whise but different under the hood. very nice car :tongue3:
forcefedhatch
forcefedhatch
thanks man...its fun to drive when its warm, anything below 60* and its too cold for traction lol..
Passenger
Looks good. Are those flipped BBK's? Debating on buying a used set for my kit or using the old stock manifolds I've got laying in the garage
forcefedhatch
forcefedhatch
yeah flipped bbks..they sealed like shit on the h-pipe so i said fvck it why not gring off the flanges and weld on some v-bands lol.thats where it started!!
auto_x5.0
You give me hope to one day holset my 94 GT....I have a friend who took a holset off his Cummins and he said he would sell it to me cheap, so just waiting to see what happens now.
Great vid btw
forcefedhatch
forcefedhatch
thanks and yeah holsets are really a great starter setup because they put out great power and... are super cheap, as well as a very durable turbo as well.. they are on diesels for a reason, and diesels are designed to be workhorses and or some have been million mile turbos..great starting point..
Passenger
If you wanted to change over to, lets say a Master Power T70 (Just a hypothetical question, not saying its an upgrade) what all would have to be changed on your kit thats setup for the Holset?
Passenger
downpipe would connect the same, no special oil lines or anything for the holset or anything?
forcefedhatch
forcefedhatch
i used an adapter to make the holset take a -4an feed line and the return was standard -10an..,now the downpipe would need whatever flange of whatever turbo you choose as well...
Passenger
Just noticed I used "anything" alot in that last post. Are the HE351VE's not variable vane? If they are how are you controlling that
forcefedhatch
forcefedhatch
he351ve's are variable vane.. i set the vanes to when i wanted it to spool.. i have it set to where i see boost at 2800 rpm.. i just opened it all the way and slowly closed them more and more each pass i made in the car.. then once i liked where the boost start point was.. i marked it and tack welded it in place... i am now using a 46mm external wastegate to control the boost and an electronic boost controller that controlls boost per gear.. in 1st or in launch mode.. i hit 4.5 psi then in second and throughout its at 10 psi.. or it works great just off of the wastegate as well... you can do what i did.. find your sweet spot,tack it there, and control the boost externally and it wont fall off, and will keep power throught the whole rpm range.. thats why a large external gate is beautiful on these turbos..
