KB on a PI swapped 98
DropTopPony
South Jersey
I will most likely go that route in 2-3 years. I have the FRPP kit (eaton) waiting to go on and i doubt that will satisfy me forever so eventually i will go 2.8 KB.
DropTopPony
South Jersey
Best bet to find SN95 PI swapped KB's would be on the MPH forums.
The KB kit for the NPI was not that popular because it was not intercooled and they stopped making it. I have only seen one person with a PI swap car and he had the 2.2 i think and heads/custom cams etc and was in the mid 600rwhp area.
97stanger
better make sure you have a built motor with the bump in compression, especially if you plan on running more than 8psi
KB98GT
KB98GT
Delaware, currently in asscrackastan
My compression has been taken care of. my guy installed custom cometic gaskets to bring the compression back down. so thats not a issue. my swap was done right with all intentions of putting a kenny bell on her. but thanks for the warning. and there are plenty of guys running around with the 9psi intercooled kit with no problems.
GDawg
Oh really...? I have a KB intercooled on my NPI. It was the 5.0 that had the 1.5L that was not intercooled.
And if you think the 1.7L for the NPI was not that popular just ask us guys that are making 350hp + with a 9lb pulley. The 1.7L was replaced with the 2.1L for reduced heat among other things and can be used by the 98s.
Btw, I've asked KB this question and they would not answer me. So, I'm guessing they would not warranty it cause it's not built for that and their chip is not tuned for that.
KB98GT
KB98GT
are you still running on the stock block? we are going with the 99-04 intercooled kit.
GDawg
Your quote is messed up. But if you are asking if I am on a stock block... yes I am. At 9psi I'm looking at 383hp at the block with their tune. If I want to up it, I can go all the way to 500hp (14psi) but I need some internals. Depends on the A/F and timing too.
DropTopPony
South Jersey
I am getting old, i forgot they did have a IC'd kit for 96-98. If i did go with one in the future it would be the big boy 2.8.
GDawg
1.7L was the largest they had when I bought mine. You really don't need to go that big unless you have some serious engine mods. With a few small mods I can take my car to 500bhp which I think is more than enough for a vert. Btw, I'm 51 so I'm a little old too...
Twista
You sir are my idol. =]
KB98GT
KB98GT
[/quote]
Yea thats what i was asking. thanks for your input. Internals will come for me eventully but for now i am going to roll with the stock block. In two weeks i will let everyone know how she turned out.
Thanks for all your input everyone.
justinschmidt1
Matt will hook you up, his tunes are safe as far as im concerned.
Im running 11 psi through my PI motor with full bolt ons, long tubes, with no problems so far.
The KB is kind of hard on the internals though so I would definately keep it like 9 psi tops
KB98GT
KB98GT
Yea mat has been doing my tunes for a while now. my last R&R home i finally had him tune it on the dyno 265RWHP not bad with the old slush box. 9 psi will be the limit for a while till i can get a built short block. I most likly go with a JLP when the time comes. we will have to meet up when i am home and hit the track.
