MasterDot
Hello everyone, I found a kenne bell 2.2 for a 4.6, I was planning on swapping manifolds/ snouts for the 302, any one have experience on that? And do you need gaskets of some kind for taking the manifolds off? Or the snout part? Also I was wondering if anyone had a pulley chart for the 2.2? My engine was on a 5 ish psi on the 1.5 KB I had, unsure if the chart differs or if I use the same setup will it be around the same amount of boost? And then if I change the pulley will I have to go smaller or bigger for more boost?
2 images, left is 2.2 by itself;
Right is my current setup kenne bell 1.5 with the 302 manifolds, and then the 302 manifold example in plan to try and put on a 2.2, and hopefully the snout changes over.
Thank you again for the help!
