Kenne Bell Build Up
xander0561
Hey everyone,
Just thought I would share my thoughts and goals with you guys to see what you thought.
So here is the Build List.
1. BBK ceramic coated long tubes
2. stage II porting on my heads
3. Built MMR short block 8.5:1 compression
4. Kenne Belle 2.1L blower & all the goodies that go with.
5. Stage 1 spec clutch
6. Aluminum flywheel and drive shaft.
7. And a nice set of aluminum valve covers.
I hope to run around 10lbs of boost with some good numbers. I don't want to go any higher than that for now because of my trans and the fact of gas mileage. With the build will be going a nice set of fuel and boost guages.When I get back from basic training I will be starting on this :) Anyway thought you might like to know what's in the works. Give me your 2 cents if you'd like :thumb:
X
xander0561
Magic said:
Sounds like a good build!
Dont forget to upgrade your fuel system!!!!!
Yea, Im hoping i get all that in the kit. I believe they offer a boost-a-pump with it.
MustangChris
Aurora, CO
the only thing it doesnt come with is 1 degree cooler spark plugs.
also, you have to switch from a return line EFI to a returnless EFI system on the 1996-1998 4.6s with the KB. They dont offer a kit that works with the return line EFI.
Other than that, sounds great... 10psi at that comp. is pretty moderate... it will be a great street/strip car for sure! :thumb: :thumb:
GDawg
Cool! Are you getting the inter-cooler too? I had to put my IC a little higher than what they wanted cause my car is so low. I almost ripped it out the first day. As soon as I finished installing my KB I fried my clutch so good move on that. I have a "Speed of Sound" 'A' pillar for my gauges. Those are pretty nice. I've yet to dyno tune mine. It's been a rough year and a half.
X
xander0561
Hey guys, thanks for all the support.
Yea I can't wait to get going on this project. :banana:
