Knuckles Build Thread
Status
Not open for further replies.
Knuckles@Empire
-Never Forget-
In front of you
Like the title says this is a feeler thread i have rarely been on sn95 forums in the past few years my cars have had to take a back seat to my family. Im finally back and ready to finish my 1996 cobra the car will be going into the shop this week to finish her up. The feeler part is do you guys want a thread kind of narrating as it comes along, without getting into to much detail the car is getting its hellion turbonetics t 76, and auto maybe a th 400 likely and a host of other good things to finish the short block that ive had done for some time. Let me know what you guys want ill be down at the shop alot so pics and what not will be a plenty.
gtzachh
Re: Feeler Thread
i love the detail filled and picture filled threads
Knuckles@Empire
Knuckles@Empire
-Never Forget-
In front of you
Re: Feeler Thread
Well then details is what you shall get :icon_salut:
Ill give a brief run down of the parts list so far.
Drivetrain:
4.6 Teksid Block stock bore
cobra forged crankshaft knife edged
Manley H beam rods
Diamond Custom Pistons compression is around 10ish to 1
ARP everything
Ported and Polished Heads, i cant remember the exact amount but they did do a valve job on it
FR 500 Cams and Valvetrain
Block Girdle although for the life of me i cant remember the company atm
MMR 7 QT. deep sump oil pan
MMR RTS Sheet metal Intake manifold
as for accesories and pullies go i do have underdrives BUT this is juat a race car so i will likely just be running a water pump to crank shaft belt.
I have yet to decide on a tranny although it is looking like a th 400 is what i will be going with.
Aluminum FRPP driveshaft
Rear End:
Stock 8.8
It has my old 4.10 gear in it right now but i definetely believe we will have to step that down once we get the motor up and running.
Moser Spool
strange 33 Spline Axles
C-Clip eliminator kit
FRPP SVO cover
Suspension:
Front,
Full Q A1 K member and A arms
Removed cobra sway bar
I believe they are Maximum Motorsports Coil overs
Lakewood 90/10 struts
MM Caster Camber plates
Rear,
Strange 12 way adjustable shocks
Eibach Drag Launch rear springs with air bag in left rear.
BBK upper and lower arms
Power Adder:
Hellion Turbonetics T76 kit
We are currently deciding if i will use my fogger kit on it as well atleast off the line to spool fast and leave hard, i have a full Dual Cheater Fuel and N2O Solenoid kit capable of some fairly high spray.
NOS intercooler sprayer
I should add that the car is fully striped of all unnecesary things. I have done alot of weight reduction on it.
Electronics:
MSD dis 4 with dual coil packs
i have yet to decide what fuel management we will be using to tune it with will tackle that when we get there.
Wheels/Tires:
Weld Draglites all around skinnies up front dont quite remember the size and 15x10 out back with M/T Drag 28x10.5s
I have probably forgotten stuff if anything is blaringly obvious i didnt mention and would like to know feel free to ask, i will add pics ASAP maybe some by tonight before i take the car in to the shop. Anyways thanks for reading.
Knuckles@Empire
Knuckles@Empire
-Never Forget-
In front of you
Car should be headed out to 1st performance on friday turns out some of my stuff got a little delayed on an order. By the way big shout out to the boys over at MMR there customer service is second to no one. They have alot of good deals going on as well. I should add im simply aq customer of theirs not sponsored, they are just that damn good.
Status
