leaking oil filter
I
Insayne
Both mobil one and k&n basically same filter. Adapter on a gt? I thought it was straight to the block?
castine917
wyoming, mi
oops, your right. ford is off block. was thinking of other engines.
<----- tiptoes out back door.
blkmcnasty
Illinois
Is this a recent problem or has it always been like this? You are finger lubing the o ring before install right?
I
Insayne
No double o ring yes I am oiling the o ring first. I didn't notice it the first couple of oil changes. Maybe the last 3. This last time there was oil all over the rack and lines and frame and control arm but it wasn't double o ringed.
I
Insayne
Good. I just replaced the rack and pressure lines. The leak was clearly motor oil.
Addermk2
remove the filter, clean off the spindle and mounting plate, and look to see if there is anything tuck to the mounting plate itself, or if it has any kind of markings, deformations, or irregularities that could cause a poor seal
I
Insayne
Ok and if it has marking or scarring on the sealing surface what's the best way to freshen it up
2slo95fiveoh
Lawrence, Kansas
A dart based 331 stroker usually takes care of it......
it depends on the extent of the scratches.. If it is deep enough to cause a significant leak like that, it's probably
nothing that can be saved... But I would do as Addermk2 suggested, then cross that bridge when you come to it.
Addermk2
You would be surprised what you can do with a really clean surface, some JB weld, and a razor blade
Staff online
