Lets Talk Water Temp. Sensor Mounting Locations!!!!!!
SRT Handz
So i am installing my Auto Meter Electric water temp Gauge next week.... but i am still undecided on where to mount the damn sensor. I have been reading on every damn Forum on the different mounting locations. I really dont care where it needs to be mounted, i Just want the best Reading Possible.
So Guys, where do you guys think the best place to have the Water Temp sensor Mounted? Where do you Guys have Yours Mounted? I have read alot and narrowed it down to these locations.
1. Coolant Plug on Side of Block (Heard This Give Bad Readings Due to Heat)
2. Tap the Thermostat Housing
3. Auto Meter Heater Hose Tap
4. Autometer Radiator Tap
what do you guys suggest?
94 DropTop
I just took out the stock one and mounted the autometer one there. :thumb:
SRT Handz
not an option...i wanna keep my dash gauge working
SRT Handz
DFG_Pimpin said:
I'm putting mine in the block, that is where most places have recommended to me.
what do you think about the excess heat?
19mustang95
I've been told that that is the best/most accurate place for it to be. And the people that told me this are people that i would trust with my car, and that isn't something i do alot of.
94Pro-5.0
Little Elm, TX
i have heard putting the autometer probe in the acutal radiator is the most acurate, but i have not done this myself to be sure, i have yet to get my guage
Stangbangin
I guess to me I would put it so you can get the truest reading on actual water operating temp. I would say thermostat housing. It would seem to me if it was in the radiator it would give you a cooler reading since it would have been cooled already.
Paul
Either tap the thermostat housing or just stick it in one of the ports in the intake. I've been through this before and tested various ports on the intake. There was never more than a 3* variation between all of them.
94 DropTop
You could just buy a aftermarket housing. I have a chrome on that I bought from someone on this site, and it has a plug where i could of put it but i figured it was better hidden where the stock one was.
SRT Handz
have you tried the Drain plug on the side of the block?
Paul
Why bother? The intake is easier to get to, and you'll get an accurate reading. This isn't some complex science, just stick it in the manifold and call it a day.
SRT Handz
well, i would have to drill and tap a hole for it. I would have to remove the manifold because i would wanna do it clean and get no shavings in the cooling system.
the bug on the side is already tapped and not that hard to access.
.....i could do the Thunder Dave Thermostat Housing Mod
Paul
Doesn't your intake already have a spare 3/8" NPT port in it? Or did the modulars not come with them?
Popping the t-stat housing off would be super easy. Only problem is that 3/8" NPT tap isn't going to be cheap. I bought one a while back and I think it was like $20. That sucked.
J
joelbegt
ford put the temperature sensors on the crossover probably for a reason, but idk why :dunno:. you or a shop could probably make another hole and tap it somewhere on the crossover.
Blind
what I did was put my autometer sensor where the stock one was, and I remounted the stock one in a different location.
stang94X
why do you want to keep the stock one working, its a useless gauge
SRT Handz
Because i like keeping everything in order...just like i installed my Oil Pressure gauge so my stock one still works
