Line lock
voidfinger
I haven't seen any for the 96-98 ... only ones i seen was the ones for the 99 up... don't know if they can be used on the 96-98 "shrugg"
MustangMatt96GT
under the 94-98section on SLPs website, it shows the 99-04 line lock, but i dont see how their would be a difference.
L
lizzyfan
I saw that but have been told their would be!
Jrgunn5150
I had a Hurst in my 97, worked fine. It wasn't application specific, just a line lock I had to cut and splice the lines for.
FYI, my 97 did not have ABS front or rear, if that makes a difference.
95PGTTech
a 99+ line lock WILL NOT work on a pre-99, the brake lines are different. you need to get a universal one (hurst, summit, etc.) and make your own brake lines. a properly installed line lock will not affect the performance of the brake system when it is not engaged - manual brakes, power brakes, ABS/no ABS, custom proportioning valves - none of it should be affected.
black_96gt
I used two Hurst roll control kits. One for each front wheel. This keeps an even application on the fronts so the car doesn't turn sideways during a burnout. It also makes the bleeding of the brake system easier.
L
lizzyfan
So this is what's needed, no?
http://store.summitracing.com/partd...HUU-5671516&N=700+4294908331+115&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=HUU-1745000&N=700+115&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1&part=HUU-5671510&N=700+115&autoview=sku
Jrgunn5150
Well the line loc is, can answer on the lines, I just went to CarQuest and made my own.
95PGTTech
if you look at the kit, they are just general selections of fittings and lengths of line. as stated, go to your local auto parts, and make/bend yours to length. the only even halfway difficult part of the whole process is flaring the ends, which any reputable brake shop should be able to do no problem.
