List Your Mods!!!
fordtech
What up everybody Im new here and here are my mods
95 cobra crystal white
Ported and polished cobra Upper and lower intake
24 pound injectors
bbk 70 mm throttle body
kirban fuel pressure regulator
fluidyne radiator
mac headers
underdrive pulleys
ford racing 9mm wires
magnaflow high flow cats h pipe
msd ignition coil module and 6al ignition box
strut tower
sub frame connectors
mcleud clutch with adjustable cable
steeda Tri ax shifter
ford racing 3.55 gears
brembo slotted and drilled brake rotors all around
and cobra R 18" wheels
DisturbedRacing
Fox computer swap
K&N cone filter(soon to be replaced by a custom cold air)
Prof.Prod. 70MM TB
stock mass air & injectors(80mm mass air and 42# inj's soon to be installed)
EGR plate deleted
RPM2 intake(ported & gasket matched)
1 in. intake spacer
Mallory Ignition, stock distrubutor w/MSD cap, MSD coil, FMS wires
Windsor SR heads (home done full port & polish, 3 angle valve job, bowls polished & blended, gasket matched, k-motion springs, new seals, retainers & keepers, o-ringed for wire lok gaskets, ARP rocker studs)
FMS tall valve covers
FMS 1.6 adjustable RR's
FMS Stud girdles
FMS E-cam
86' pistons, notched for valve clearance
stock polished rods w/arp bolts
stock polished & knife edged crank
ARP main studs
ARP head studs
stock t-5 w/ center force & hurst shifter
Firewall adjuster, adjustable cable, svo quadrant
FMS aluminum driveshaft
Driveshaft loop(bolt in)
FMS 4.30 gears
welded diff.
Pro-Stars (fats & skinnies)
Cheap-o 3.5 radials front
Mcqueary 285/60/15 bias plys rear (will be switching over to a 28/10.5/15 ET Drag)
JD's Performance tubular upper and lowers w/solid bushings
Lakewood 50/50's
Eibach rear springs w/air bag
Lakewood 90/10's
Moroso trick springs cut 1 1/2 coils
Still have stock k and a-arms
Weld in sub frames
Custom dual nozzle dry shot, plumbed into intake, modified nitrous regulator, NOS purge
MAC equal length shorties
Cheap-o 2 1/2 O/R H pipe
MAC pro-dumps
Dual electric fans
R/R Boss hood (fiberglass bolt on, deleted latch, pinned on in front)
Autometer gauges (oil, water, tach, ect..ect)
Holocomb battery relocation kit (in trunk)
Weight reduction!! Weight reduction!! Weight reduction!! (Still needs driver weight reduction!!!!)
Welp, thats all I can think of right now. I'm sure I missed something. I haven't had her running long, about 2 weeks. Still tieing up some loose ends and hope to take it to the track before summer is out.
krahkin
New to site and wanted to post my current mods:
AFR 165 w/61cc
Comp ProMagnum 1.6RRs
95 Cobra Intake
70mm BBK T-body
76mm C&L MAS
BBK Strut tower brace
Eaton Posi
Moser 31 spline axles
FRPP 3.73 gears
MM Panhard Bar
Kenny Brown Subframe Matrix
Centerforce Dual Friction Clutch
FRPP 30lb Fuel Injectors
BBK 255lph Fuel Pump
Trick Flow Stage 1 Cam
FRPP Double Roller Timing Chain w/steel thrust plate
Crane Hi-6 ignition and coil
Trick Flow Hardened Pushrods
BBK Full Length Headers
BBK Offroad H-pipe
Flowmaster mufflers with turn downs
BBK AFPR
Thinks that's all currently :naughty:
