Loctite head studs yes-no?
OLD H2S
Silver Spring Maryland
What is your opion? I have an aluminum 3V block and ARP studs. I had problems on Terminator motors with heads lifting but I do not know if the studs were losing.
96blak54
Staff member
Lawrenceburg Kentucky
No. Use small ball bearings at the bottom of the hole and then tighten the stud against it. This helps to keep the stud straight when its tight in the hole.
