Lowering & LT's
navarro98gt
I will be installing my new suspension goodies this weekend and I’m wondering if I’ll run into trouble with my LT’s hitting the A-arm’s. On both the driver and passenger side’s the LT’s are real snug, almost rubbing the A-Arm’s. Will this be a problem with the new drop? Thanks
realitygt
no problems hitting the a arms, what might happen is you scraping the ground cause the lt's hang down tho :dunno:
vermilion
maryland
might have to creep over speed bumps. how low are you talking about? and a-arms should be fine. and make sure you have clearance from steering shaft. the plastic tends to melt. and best way is to drop the k-member. it took me and a buddy 2 hours to drop and hang up with tie wire the steering rack. just remember where everything goes.
