Main bearings?
Lebedin8654
If your using a stock crank that hasnt be touched and just needs a lil polishing than you run standard bore bearings right?
topless95
always measure using a micrometer, otherwise you could have irregular wear and oil pressure issues(to the mains). Generally when they polish the crank journals they can tell/sell you the right bearings
