Mild 4.6 build ?
Sn95Willis
Baytown Tx
Well I have had a couple issues come up and I am going to scrap the 5.4 2v swap for now. I am going to juts use the heads of the 5.4 and swap over to the 4.6 now. My ? is whats the nastiest cams i can run with stock head and some N2o. Ill prob upgrade springs if that will help.
Also Since I have the P.I intake already on the car and I have a complete set of P.I. heads and valve covers what am I needing to put the heads on..
I know Ill needs Head gaskets, head bolts but what else?
duff daddy
my cams on a car with a p51 and an auto went 11.7 last year off slicks and wacking it off an idle at the line... i had these comps XE270AH
like i said he has patriot heads, thoes XE270AH comp cams, p51 intake, and an exhaust and tune... went 11.7 on squirt and a12.7 na
DropTopPony
South Jersey
From what i'm hearing the Hitech stage 2's are the shizzle..... but you need to have your valves machined for clearance and since your heads are off thats not a big deal. Hitech does it for a good price if you send them your valves.
Willis_98GT
DFW Texas
i wanted the hitech 2s but i didnt want to pull my heads again for the valve work, so i got a set of the xe270ahs on the way they will be a very good cam
hey duffy, what shot was on that 11.7 car?
lordgufi
270's will still require work no? whats the duration and lift?
or am i thinking 280's?
