mods to buy?? Help!!!!
Sn95Willis
Baytown Tx
I am stuck not really sure what i should spend some money on.. I have the money for a mod or 2 but I already have one planned as its an appearance mod. Now I am stuck between chosing one or the other..
Upr rear coil-overs
or
Upr 70mm tb and Plenum.
Which ould u guys go with?
duff daddy
looks like you actually run the car, whats your current set up for suspension front/rear shocks/springs?
Sn95Willis
Sn95Willis
Baytown Tx
Yea I run it at the track.. Right now its pretty much stock. That Pic was from when I first got it getting some starting point times.. As far as mods it has. Now come november Ill be swapping in the 5.4 i have in the garage and a 125 shot of N2O.
O/R X pipe, Slp mufflers
K&N CAI
4.30 gears
03 Cobra A-Arms
LOwered ith 87 GT that are cut a little.
nd Diablosport Predator.
Inspector13
If your swapping the motor I wouldn't waste the money or time on something for your old motor. I'd go with the suspension parts. Better chance of getting that beast to hook when it's done.
Sn95Willis
Sn95Willis
Baytown Tx
Well see thats the thing lol.. he TB and Plenum with go over on the 5.4 when it goes in to.. Either way I wont be wasting either of the parts I get..
Inspector13
Ah that makes it a different story. I'd still go with the coil overs. What good is power if you can't put it down.
Crone
^+1 suspension, do the make the plenum and tb any bigger? Since you'll be rockin a 5.4 and all....
duff daddy
personally i would find a set of 4cy fox springs and some adjustable struts up front and cut your oe' springs in the rear to the steeda heigh (i have measurements) and then call it a day and youll transfer weight pretty good
