Momo steering wheel horn switch
solis
abilene
hi guys who has installed a momo steering wheel?
how did you wire the horn switch? i used the lmr/am how to to install the steering wheel, but they had no wiring info.
Interested! Im tuned in. Ive been poking at the idea of an aftermarket steering wheel.
Come on guys post up!
evilcw311
Most Evil Member!
Louisville, KY
Put that in your window. Problem solved.
Your welcome.
solis
abilene
Who's steering wheel adapter did you use?
Jake
I used the momo adaptor, I also have a foxbody 2 prong horn switch.
I bought the switch thinking it was going to be the same, i have to switch or crimp the lockspring connector.
I can't say I have ever seen an aftermarket wheel on an sn that looked good enough to make me consider it. I think its normally the difference in size between the steering column to the center of the wheels that throws it off. The columm always looks 2x or 3x bigger then the wheel and just looks funky. I have seen more then a few stock wheels wrapped that looked a 100x better then the stock wrap and a few times better then any aftermarket wheel.
solis
abilene
This momo wheel looks great, I really like it. I had a sve fr500 wheel but it was unsafe, it was rotating on the shaft.
solis
abilene
Which one? If it was rotating then it probably was not installed correctly
i had the one from lmr, It was installed correctly. Let me rephrase that, the wheel was rotating on the press fit bushing that goes into the shaft. The wheel is not completely solid.
Jakespeeds
Camarillo, California
Its been awhile since I put mine on. I know how I did it. It was not a simple process so everything including the cruise control worked again. I don't think I can help you out too much since I never tried to use a Fox horn switch in my conversion.
Jake
solis
abilene
Jake
I just want the horn to work for safety inspection purposes here in TX, once I move back to San Diego CA I won't need it. I knew I was going to loose cruise control, all I want is the horn to work.
You might want to double check then removing the air bag in some places will also make it fail inspection.
Markstang73
