Moving stock k member
Notthenow
I always thought the passenger side front tire was a little farther out than the driver side. Now installing a set of Pacesetter headers the passenger side rests against the k lower bracket while the drivers has about 1/2" clearance. Dropped plumb bobs and measurements show back to front good, but has side to side off 7/16" toward passenger side. It proves the issue. Now to more the K. I have the engine supported from above with an engine lift bar. Anyone do it this way and have an idea how to shift the K about a 1/4" toward the drivers side?
Benni614
Delaware
I believe upr makes brackets for this I used them with there k member but without it u might get a smidge of movement. But usually I have had one person pry against the k member as I ran down the bolts. But I also dumped the original k member because of fitment issues anyways.
N
Notthenow
Hey Benni, are they brackets (UPR) to move engine over? Where did you pry on the k to get leverage to move it?
Benni614
Delaware
So yes they make brackets and I put my pry bar in where the shock is and the 2 bolts are either side pass or driver but all bolts has to be loose a little
N
Notthenow
Thanks, I will take a look at trying that tonight.
Benni614
Delaware
Yeah no problem bro hit me up on IG benni614_turbo2v its easier because sometimes this app doesn't show notifications unless I open it.
Pleasanton/Hayward, CA
moving the k is a bitch. if you can unbolt the engine from the k, support the engine and then have majority of weight off the k member you can move it easier. a pry bar in any logical spot on the k should do the job
N
Notthenow
Thanks Frank, that what I figured. I have the rack off the k and accessories off the motor and an engine support in place with the car up on 12" "lincoln logs" I will transfer the front end to the frame rails, take off the wheels, loosen the k bolts, and see what a crow bar and some luck will do.
N
Notthenow
I gotta say that is so true. I do not miss what happened to cars when I grew up in Illinois. Rotted bottoms of body panels and floors and using WD 40 and an acetylene torch to heat up or cut off rusty bolts.
N
Notthenow
Ok, to put a lid on this question: the stock k member is NOT adjustable. The left forward bolt hole is concentric. The other 7 holes are slotted of larger, but that is simple so you can line up bolt holes from production tolerances. I am attaching a photo. If I want to slide mine over more to the left side I will have to make the needed openings.20201105_164358.jpg
N
Notthenow
I'm tempted to try an aftermarket k and I do respect MM, but I don't like being forced to go coil over and A arm.
Werecow
Virginia
You don't have to go tubular arms and coil overs... Use a team z I think they'll use factory arms, if not you can use UPR plates on team z's arms and use regular coils without using coilovers.. you can use your coils and struts that way..... Then whenever you can, drop off the plates and your ready for a coilover kit just use your existing strut..
N
Notthenow
Werecow, I looked at that too, but so many say the Z and UPR are not really for DD street use whereas the MM could handle it.
evilcw311
Most Evil Member!
Louisville, KY
First things first. The team z can be used with factory a arms but you have to lightly modify them and yes, you need spring perches.
Team z is fully capable of being daily driven. They’re one of the most popular products out there. What you have to look at is whether your car is more street/strip or if your a corner carver. They have a k member specifically for those who will punish their car in the corners that is heavily reinforced for such.
What your hearing is all the mm fanboys who say it’s mm or nothing. Don’t believe the hype.
peasant99
